I am doing some labor work on a rig and am confused about something. I heard from my superiors that we are injecting steam at 180°C with the wellbore pressure being 2 MPa. If I look at these conditions on a steam table, shouldn't the steam be compressed water?
You are correct, that water at 180°C and 2 MPa will be a liquid.
Perhaps the steam is not being injected at the "wellbore pressure", or its temperature rises during the injection process?
Water Phase Diagram
Most SAGD facilities inject steam at much higher temperatures and pressures (often over 300°C). Downhole temperatures may be 180°C at 2 MPa.
