I find this scheme here
1 - is data stream come from computer. This 'data' is an electric signal moudulated by the n°2
2 - this is the electronic circuit inside printer that
a) activates the corona wire →
b) the corona wire charges up the photoreceptor drum
a) at the same time circuit activates the laser to make it draw the image of the page onto the drum. The laser beam doesn't actually move: it bounces off a moving mirror that scans it over the drum
My question are:
when data stream come from computer to the printer inside the electronic circuit what happens inside this electronic circuits ? How mechanism 'tranform' this electric signal of data into instruction for laser diode and moving mirror ?
But this step is possible only if you have correct modulation between data stream and instruction laser otherwise printing should be wrong and electronic circuit may break or not work properly.
What modulation technique is used for laser diode ?which components inside electronic printer is needed to drive and control this ?
