I have a small assembly with several parts misaligned. By turning the grey wheel, the grey block is to rotate about its axis (Axis 1). The problem I have is that the grey wheel can't be turned further anti-clockwise given the current position. It seems to be jammed.
The red connecting rod can freely slide in the yellow bore, which itself can rotate with the rod in the grey bore. I'd expect the red rod to extend further and turn the yellow connector.
Does anyone know why the wheel might be jammed or how it could be modified to allow continuous rotation?
