This question is about a thought experiment described in this YouTube video: https://youtu.be/JzwfzgfJiJ4?t=1139
The video is attempting to explain how a jet engine works, specifically, the importance of having a high compression ratio. The thought experiment seems to consist of the following:
- Isothermal compression
- Isochoric heating
- Isothermal expansion (<-- work done on the environment here)
This isn't the Brayton cycle. Significantly, the process of adding heat in the Brayton cycle is isobaric, with the expansion of the gas happening immediately and continuously.
I don't fully understand the Brayton cycle, and I'm not trying to sneer at Tech Ingredients. But these processes seem sufficiently different that I'm not sure what correct intuition can be derived from them.
I am aware that the Brayton cycle can be analysed in temperature-entropy coordinates by using the Carnot cycle: "Ideal Brayton cycle as composed of many elementary Carnot cycles" https://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/node47.html That's obviously a lot more complicated. So what is going on in the Tech Ingredients explanation?
