Can someone tell me what influence an angled wall has on the flow over a triangular weir compared to a "normal" vertical one if the wall is angled against the upstream as in the picture?
10
$\begingroup$ Make both and test them. A good learning experience. $\endgroup$– Solar MikeCommented Nov 30, 2022 at 15:25
$\begingroup$ I do not have that option $\endgroup$– NilCommented Nov 30, 2022 at 15:36
$\begingroup$ TLTR: looks like google may be your friend: uobabylon.edu.iq/eprints/publication_3_3905_6015.pdf $\endgroup$– Solar MikeCommented Nov 30, 2022 at 15:43
1$\begingroup$ openchannelflow.com/blog/… $\endgroup$– Solar MikeCommented Nov 30, 2022 at 15:55
1$\begingroup$ They give you a reason, again read carefully. $\endgroup$– Solar MikeCommented Dec 1, 2022 at 5:01
Show 5 more comments
1 Answer
I would think that at high flow rates the flow over an angled weir would tend to push more water over the weir. At lower rates there would be no difference. I imagine you owuld need to determine this emperically if this were the only way to build your weir.
$\begingroup$ As one of the references I gave points out that the angle of the notch affects how the water sticks to, or separates from, the notch then that causes errors - and the reference point out that they can be large. So not so sure about your "no difference"... $\endgroup$ Commented Dec 1, 2022 at 7:00
