Given everything else equal (e.g. same overall amount of magnetic material, same strength magnetic material, same coil, same power supplied, etc. etc.) which of these two magnetic configurations of a voice coil actuator would produce higher amplitude sound from the speaker cone?
I assume 1 should be better than 2 (and even that 2 shouldnt really work at all), but my colleague is claiming no 2 works better!
P.S. The non-magnetic filler material is just a sliver to keep the two magnets stuck together
EDIT: Apparently there is an effect which has been described before - there's a question here about it. In this case I suppose my question becomes - why aren't voice coils made using 2 opposing magnets like this?
