What would be correct approach for selecting welding parameters for MAG (Metal Arc Welding) welding of carbon steel. How to select information that will go in WPS (Welding Procedure Specification) ? Is there mathematical approach for parameters determination ? What step will one take to do so ?
Terminology used is European.
  • $\begingroup$ What needs to be welded? What support is needed? Will it need a backing plate? Will it be achieved in one pass? If multiple passes, what clean & prep needed? Terminology is European. $\endgroup$
    Commented Jun 8, 2022 at 20:43
  • $\begingroup$ Hello Solar Mike, the question is general. There is no specific situation. I know that all those factors will influence welding parameters selection but general answer with some example will also be good. Mostly Voltage and Wire Speed determination is my focus. $\endgroup$
    – Sysrq147
    Commented Jun 8, 2022 at 20:45
  • $\begingroup$ Get a book on welding. $\endgroup$ Commented Jun 9, 2022 at 0:27
    $\begingroup$ You are eventually going to also need a PQR. $\endgroup$ Commented Jun 9, 2022 at 0:29
  • $\begingroup$ I guess you mean SMAW , aka "stick". Continuous wire feeds are more common today . $\endgroup$ Commented Sep 10, 2023 at 18:25
Use the welding wire/ electrode manufacturer guidelines to choose welding parameters. As a welding engineer, I have experience using different welding process so I know what parameters best suits me. Also you can use trial method using scrap material to find suitable welding parameters.
