How can I merge two input into one? (gear mechanism) There are a tube, a shaft, and a gear. The shaft is in the tube and both of them rotates in same direction. And I have to deliver the power to the gear at the bottom. How can I merge two input and deliver it to one gear without interrupting one's rotation? There would be no reverse rotation of gear.
One way you could do that (it might require significant rework) is with the use of a differential /planetary gear system.
The planetary gear arrangement with the sun-planets-ring might lend itself more to the endeavour
i.e. attach:
  • the red shaft to the sun
  • the outer (blue) tube to the ring
  • the gear to the planet carrier.
There are a lot of asterisks, i.e. what is the rpm on the output compared to the rpm of the shaft and the ring, however, since you did any information I assumed that you wanted to transfer power/torque.
you can use a mechanism like a car differential, connecting the tube and shaft to the sides but in a reverse sense. And the output is where it is in a car is the engine shaft.diff
