I know that the equation for displacement is:
S = V0 t + $\frac{1}{2}$at$^{2}$
With S being displacement in metres, t is the time is seconds, V0 is the initial velocity in ms$^{-1}$ and a is the acceleration in
ms$^{-2}$.
However, if the time used in the equation is milliseconds then what would be the unit of the displacement S?
    $\begingroup$ How many milliseconds in a second? $\endgroup$
    Commented Dec 15, 2021 at 11:44
3 Answers 3
In SI you have:
$$S [m] = V_o\left[\frac{m}{s}\right]\cdot t[s] + \frac{1}{2} a \left[\frac{m}{s^2}\right]\cdot \left(t [s]\right)^2 $$
If you only used ms for time then 1 s = 1000 ms. So if the time was expressed in ms then 1 ms would be equal to $\frac{1}{1000}[s]=0.001 [s]$. Therefore:
$$S [m] = V_o\left[\frac{m}{s}\right]\cdot \frac{t}{1000}[ms] + \frac{1}{2} a \left[\frac{m}{s^2}\right]\cdot \left(\frac{t}{1000} [ms]\right)^2 $$
$$S [m] = V_o\left[\frac{m}{s}\right]\cdot \frac{t}{1000}[ms] + \frac{1}{2\cdot 10^6} a \left[\frac{m}{s^2}\right]\cdot \left(t[ms]\right)^2 $$
Just multiply the units:
units = $ \frac m {ms} + \frac m {ms^2} ms = \frac m {ms} + \frac m {ms} = \frac m {ms} $
  • $\begingroup$ Oh okay so the units are just millimetres then ? $\endgroup$
    – Dan Khan
    Commented Dec 15, 2021 at 12:02
  • $\begingroup$ Sorry, Dan. My answer is garbled and I don't have time to fix it. Can you unaccept it and I'll delete it. $\endgroup$
    – Transistor
    Commented Dec 15, 2021 at 12:41
    $\begingroup$ Just think of "milli" as a multiplier that means "$×10^{-3}$".... so $15 ms$ means $15×10^{-3} s$. Same with any SI unit prefix $\endgroup$
    – RC_23
    Commented Dec 15, 2021 at 15:51
The units of S (as was asked in the query) is controlled by what distance units are used in the velocity and acceleration (feet, meter, miles, etc.); not the time. Simply use one millisecond as .001 seconds and all will come out right. For example, for 5 millisecond time plug .005 for time into the equation.
