I'm trying to sense the position and orientation of an object in real-time using an Arduino. I'm able to measure orientation with ease using a 9-DOF IMU.
I cant seem to figure out how to measure linear position. I tried integrating the linear acceleration readings from the IMU (compensated for gravity) to get velocity then integrating again to get position and using filters at each step. Despite using filters I still get a very inaccurate result.
Unless there's some holy grail algorithm that can extract linear position from an IMU I have to turn to other sensors or devices. Are there any sensors/devices that measure linear position/displacement with respect to an origin (start position).
Does the following device or anything similar to it exist?
Is there such thing as device that has a cable/tether that once pulled measures the displacement based on how far its been pulled out and in what direction? (perhaps by sensing tensile forces/directions on the cable?)
