I have the following setup, consisting of a bar attached to another bar via a ball joint (indicated by a circle, and attached to the wall over a pulley with a weight at the end (the small "kg" symbol). I want to pull on one side of the bar. This is sort of like a one-handed cable row at a gym.
Top view: Side view:
But when I pull, indicated by the black arrow, the angle (in red) between the force and the bar gets wider than the 90 degrees before the pull.
Top view:
I thought of adding a blocking element:
Top view:
But this would not help, as the pulley always aligns with the pulling force vector.
Top view:
How can I pull, while keeping everything (the angle between the two bars, but at least the angle between the back bar and the force vector) at 90 degrees? I hope this makes sense. I am thinking about something between the two bars, such as a spring.
  • $\begingroup$ Put an extra handle on the bar so that your hand is inline with the pulley - making a C shape. $\endgroup$
    Nov 2, 2020 at 7:30
  • $\begingroup$ Unfortunately, I cannot pull from the middle, I need to somehow tweak this existing configuration which is part of a larger project. $\endgroup$
    – mosuem
    Nov 2, 2020 at 7:35
  • $\begingroup$ Well you are applying an offset force. It will twist. I suggested a tweak that overcomes that and you did not say no changes in the question. $\endgroup$
    Nov 2, 2020 at 7:37
    $\begingroup$ a) Can you use guide rails on either side? B) is the force applied variable or constant? $\endgroup$
    – NMech
    Nov 2, 2020 at 7:42
  • $\begingroup$ @NMech I need the degrees of freedom, but something like guide rails might be the only choice. I hope there is be another way, some construction between the two bars. $\endgroup$
    – mosuem
    Nov 3, 2020 at 7:23
Idea 1: Adjust the pulley attachment position so that it is in line with the pulling force. If this is a rowing machine, then maybe use 2 pulleys like this:
modified diagram
Idea 2: Use a linear bearing to prevent the bar from twisting:
