Suppose i have 4 empty syringes. And by empty i mean they were having the air sucked out of them, and they "contain vacuum". Assume the head of the syringe is blocked so vacuum can be formed.
I want to understand how to choose between this 4 different syringes.
My goal is to have the piston reach the highest speed possible. I don't know how to calculate what is better.. should i increase the diameter? - should i keep the diameter the same but make the syringe longer.. what is better?
When i release the piston - the atmospheric pressure will make the piston move pretty fast - and blow up the head of the syringe.
This is not a real world example. Just something for me to learn. I don't know what the piston friction with the walls is - but is the same for all 4 syringes so does not matter when comparing them.
Also i don't know the mass of the piston either.. i mean we can use a gut number like 0.25 kg. And the bigger piston is 1kg.
Now how to calculate all this? how to calculate the speed and force of the piston in a vacuum syringe?
Also i'm interested in forming an intuition of what to expect given changes to the design of this syringes rather then exact numbers. What happens if i increase the diameter 3 times.. is it better or worse .. that kind of thing.
Does it matter how long the syringe is? Can it happen that if i make it too long then the piston is actually slowed down? Is this piston constantly accelerating while is in the syringe and there is still vacuum in front of it .. or not actually? Can air to air turbulence slow things down? Where is the highest acceleration at? Maybe in the middle of the syringe ?
I say this because if we go down to 1 mm tube, then capillarity is so high that you need to push on it like crazy to make things move. I'm thinking about what force is needed to squeeze that fluid in a medical equipment (needle + tube). So when it comes to tubes like this, maybe having a higher diameter is better?! Maybe this applies to air also?
I can put the numbers in a calculator and get the result, but i'm interested more on how to think about this, not just the formula. How do you break it down in your mind - and not be wrong?
But i do want to lean how calculate the exact numbers as well. Thanks :)
    $\begingroup$ Not an answer but just a couple of observations. In an idealised world we can consider your 3 parameters intutively: The force acting on the piston head will be determined by the diameter of the piston (as the pressure difference is fixed). Greater diameter equals more area means more force, as per F=P/A. This means greater acceleration for larger diameter. Longer tube means longer time for acceleration, i.e. greater speed. Greater mass of piston, lower acceleration, i.e. lower speed. $\endgroup$
    – masiewpao
    Commented Nov 1, 2019 at 15:37
    $\begingroup$ Note these are all perfectly idealised with no issues of friction between between cylinder and piston, and no unusual fluid effects at the boundary including leaking of air into the cylinder. Funnily enough I believe this is easier to model than many other situations because there is no non-equilibrium issues within the piston system due to the vacuum. $\endgroup$
    – masiewpao
    Commented Nov 1, 2019 at 15:41
If we ignore the friction and assume total vacuum ( both unrealistic) the force on the piston with the larger diameter increases. But it is reasonable to assume the mass of the piston increases by the same ratio.
$F=ma$ and say $KF=Kma$ with K being the ratio of area of the cylinder, meaning acceleration doesn't change. of course if you have the mass of the piston differently just plug it in the above.
And obviously the longer syringe will allow the work done on the piston increase, hence its final speed increase. $W=F*x $
The final speed will be
$ v_{final}= \sqrt{2xa} \ $
And the kinetic energy at the time of impact
$ E= 1/2 m_{piston}*v_{final} ^2$
I think you're dismissing friction far too easily.
Frictionless
Since you asked for it here it is:
The forces on the piston are pressure (from the atmosphere on the back of the piston) and friction. So we have:
$$P\,A=F=m\,a$$ Where $P$ is pressure, $A$ is area, $m$ is mass, and $a$ is acceleration.
Since the area, pressure, and mass are constant, the accerations must be as well. Thus we can use the equations of constant acceleration:
$$d=\frac12 a t^2$$ $$\Delta V=a\,t$$
Combining these two can give you final velocity in terms of distance and acceleration:
$$V=\sqrt{2\,d\,a}$$
Now we can do some more interesting things if we make some assumptions about how the piston mass scales with different dimension syringes. For example, we could assume that the density of the syringe was constant, and thus the mass was proportional to the length, and proportional to area:
$$m=\rho\,d\,A$$
if we plug that in we get:
$$P\,A=\rho\,d\,A\,a$$
The areas cancel. So the cross section of the picton wouldn't matter at all if our assumptions were correct.
$$a=\frac{P}{\rho\,d}$$
$$V=\sqrt{2\,d\,\frac{P}{\rho\,d}}$$
The length/ distance cancels out too! $$V=\sqrt{2\frac{P}{\rho}}$$
Now, from your images it actually looks like your piston is the same length regardless of the length of your syringe. This would result in the mass only being proportional to area:
$$m=\rho_2\,A$$
$$V=\sqrt{2\,d\,\frac{P}{\rho_2}}$$
So in this case: the longer the faster.
However, speed might not be the factor you really care about. If you care about how hard the piston is going to hit, you might care more about impulse or kinetic energy. Ballistics usually measure impact energy when concerned with how strong an impact will be.
$$KE = \frac12 m\,v^2 = d\, P \, A$$
The energy that you impart into the piston is always equal to the volume of your vacuum multiplied by atmospheric pressure. This is true regardless of the mass of your piston.
Friction
It's likely that friction plays a significant role in the final velocity.
