It’s difficult to say when we should select the rolling element bearing or the other one, sometimes we have to consider the upsides and downsides of each to decide. Also the working condition and the load tell us which is the best option. Here I’m going to mention the most important advantages and disadvantages of both.
The advantages of plain bearing
1- This type usually have a large bearing surface which reduces the sensitivity to impact forces
2- Noiseless
3- Suitable for high and rough rpm
4- Easy to assemble and disassemble thanks to split joints
5- Very long lifespan
The disadvantages
1- High starting torque
2- High consumption of oil
3- Continue control
4- Low rendement thanks to friction
The advantages of rolling element bearings
1- Low friction
2- The starting torque is not larger than the service torque
3- Slight consumption of lubricant
4- These types don’t need continue inspection and maintenance
5- Low response time
6- Thanks to normalisation the interchangeability is often possible
The disadvantages
1- Vibrations and impacts lead to pitting and fretting so eventually the failure of rings and rolling elements
2- Limited lifespan (usually measured in hours)
3- Thanks to centrifugal force and its impact on the rolling elements these types aren’t suitable for high rpm
4- Excessive sealing
So according to upsides and downsides we can conclude the combination of high rpm, long lifespan and large loads push us toward journal bearings, for instance gas turbines, or hydraulic turbines, generators, huge ships
To damp the strong impact in low rpm we can also use plain bearings, hamers, press machines
Some industries require low maintenance, like oil and gas, here the rolling element bearing is a good option.
