Why do power plants that use the Rankine cycle use the working fluids:
- sodium
- mercury
- serine
- benzene
- potassium
Can such plants use other fluids?
I doubt many Rankine cycles use any of these as working fluids, if working fluid means the fluid that undergoes the actual phase change etc. Rankine cycle engines want fluids with a convenient boiling point - within the temp. range the machine will operate in, at a managable pressure. Most of the times this is water. Organic Rankine Cycle engines exist, these use fluids with lower boiling point to exploit lower temp. heat sources like industrial waste heat or geothermal sources. The wiki article I linked goes into the choice of the working fluid, with more explanation :
Yes, and the absolutely overwhelming majority of them do. The number that use any of the fluids you listed is trivial. Most use water.
There used to be utility scale mercury vapor turbines for combined cycle electricity generation. According to that wikipedia page, the increase in efficiency of steam turbines made mercury turbines obsolete.
