I am asked to design a pile cap which also serves as a collision barrier. What special design considerations need to be addressed in order to raise pile caps above ground level?
  • $\begingroup$ Maybe a sketch and a little more information would be helpful? What type collision barrier are you referring to? I would assume that the pile cap would also transfer lateral loads into the material around it, when it is below ground level. $\endgroup$
    – SlydeRule
    Commented Sep 2, 2016 at 10:04
  • $\begingroup$ @NamSandStorm, It is to resist train collision. No sketch as it is preliminary stage. $\endgroup$
    – joanne
    Commented Sep 2, 2016 at 11:28
  • $\begingroup$ Related: engineering.stackexchange.com/q/6531/33 $\endgroup$
    – hazzey
    Commented Sep 8, 2016 at 21:36
A pilecap is something to distribute loads into piles. There are no particular "rules" for pilecaps that mean it needs to be treated differently above or below ground. It just needs to be designed like any other structural element: for all loads that could be applied on it, with all resistances that may occur.
So, you'll need to design it for collision loads, any vertical loads coming onto it, with resistance from the piles and from soil that is against any below-ground parts.
  • $\begingroup$ I thought there could be some design implications since majority of pile caps are buried. $\endgroup$
    – joanne
    Commented Sep 2, 2016 at 11:25
