How is the armature in an electric motor energized (i.e. main conditions on signal as function of position)? Let's consider the following parameters:
- $n_a$,$n_f$ the number of armature and field pole pairs, respectively
- $\gamma_{a,k}={\pi k\over n_a}$, $\gamma_{f,k}={\pi k\over n_f}$ the position of armature and field pole $k$ ($k\in \{1,\ldots,2n\}$)
- $\gamma$, the angular position of the shaft
- $I(\gamma)$, the current in armature as a function of position ($\forall\:\theta\in\mathbf{R}\::\:I(\theta+\pi)=-I(\theta)$)
- $I_k(\gamma)=I(n_f×(\gamma-\gamma_k))$, the current in armature pole $k$.
The most important question is: should $I_k(\gamma_k)=0$ (i.e. should the current commutate whenever a field pole passes an armature pole)?
I created the gif below to illustrate. The vectors represent the magnetic moments: blue is armature, yellow is field.
