I was intrigued to read about so-called "heat storage ceramic" and was wondering how the energy stored in such way compares to energy stored in a NMC Li-Ion battery, if the latter is used to generate heat (the article lists it a 230kJ L-1). I know it is not an apples-to-apples comparison, but I am curious about any ballpark assessment, especially in terms of energy stored per kg.
The main reason for my interest is potential use in electric vehicles in cold climates. I drive an EV in Quebec, and I know that when the temperature is significantly below freezing, I can expect to spend 5-7KWh per 100km of driving simply to heat the interior. If energy density of "heat-storage ceramic" is significantly higher per weight or volume, it could make sense to install heat storage "batteries" alongside electrical batteries.
The energy density of lithium Ion batteries is between 900 kJ/L and 2430 kJ/L according to Wikipedia. This is at least a factor of 4 higher than the energy density you give for the heat storage ceramic so no gains in terms of space.
Some example ceramics have a specific gravity ranging from 2.5 kg/L to 6.0 kg/L. At the lower end, the heat storage ceramics will have a specific energy of 92 kJ/kg while the lithium ion batteries range between 100 and 265. So, if the heat storage ceramics have a very low specific gravity, then you might save a little bit of weight over low density lithium ion batteries, but the gains won't be substantial.
