Is there a way to derive a formula of modulus of rupture (flexural strength) vs compressive strength?
I want to know is there any mathematical reason for the $\sqrt{f_{c} ^{'}}$ placed somewhere in the formula?
Sign up to join this communityIs there a way to derive a formula of modulus of rupture (flexural strength) vs compressive strength?
Short answer: No.
Longer answer:
The code equations (e.g. ACI) relating modulus of rupture with compressive strength cannot be mathematically derived. It is an empirical relationship based on curve fitting to extensive experimental data.
The ASTM test for flexural strength (i.e. Modulus of rupture) is ASTM C78/C78M.
In essence, the most common test consists of loading an unreinforced simply-supported concrete beam at third points and determining the load at which fracture occurs. From this data, the modulus of rupture can be calculated.
There is generally a large amount of scatter in modulus of rupture data because a number of factors affect $f_r$ (mix design, aggregate size, rate of loading, specimen size, etc.)
Many researchers have studied the relationship between modulus of rupture and compressive strength. Relating $f_r$ to $\sqrt f'_c$ seems to provide good correlation. Data from one such researcher is shown below. (Admittedly, it's not the definitive reference, but even Google has its limits when it comes to academic publications and paywalls.) I think some of the more recent research has proposed a 2/3 power relationship, though that may only be for high strength concrete.
