Folks,
so today in the Lab I came up with this problem (see picture). It shows a cross section of a cutting machine. There's a blade moving with a constant speed $\frac{dx}{dt}$ towards the center of the roll made up of wood. This roll is turning with a adjustable speed $w$. Let's assume we keep $w$ also constant. So the questions I ask myself are as follows:
How does the rotational speed w influence the thickness of the thickness of the fibers being cutted?
What is the mathematical function of the contact point (roll/blade)?
Do the fibers have a constant thickness?
Through careful consideration of the problem, I found the answers to 1) and 3).
Yes the thickness is influenced by $w$. For 3) it can be said that after one rotation of the roll, the fibers have a constant thickness. By observing the contact point on the wooden roll it can be seen that the point makes a spiral towards the center. Basically what is missing now, is the analytical/mechanical approach and mathematical formulation for this spiral.
