So there's a permutation of rotation and translation each being either fixed or free for a column. What do each mean?
If the column is toe nailed to a plywood / beam underneath which is it?
If it's in a steel bracket nailed to a column below what is it?
If it has a 2x6 plate of a wall on top nailed to it what is it?
Does bracing in the middle of the column for either affect it?
My case is a 8x8 wood post
  • $\begingroup$ Are you asking about this in a general sense or in the various specific cases that you mention? $\endgroup$
    – hazzey
    Commented Mar 10, 2016 at 3:14
  • $\begingroup$ I was curious more in a general sense, it wasn't clear to me what the two meant. $\endgroup$
    – RLZaleski
    Commented Mar 10, 2016 at 10:44
To say that a specific degree of freedom of a support is "fixed" is to say that the support cannot translate along, or rotate about, that axis. For example, if it is stated that the translation of a beam is fixed in the X axis at one end, that means that the beam cannot translate, or move, along the X axis (in the direction of +/- X) at that end. And similarly for rotation, if it is stated that the rotation of a beam is fixed about the X axis at one end, that means that the beam cannot rotate about the X axis at that end.
When we design things, we often assume an ideal, or perfect, boundary condition. For example, idealizing a beam as being "simply supported," which means we assume it can rotate about either end and translate along its longitudinal axis at one end, usually enveloped the beam design forces of bending moment and shear force.
In reality nothing we design is ever actually perfectly rigid (fixed) or perfectly free to translate or rotate, we make those assumptions to simplify the design process. In practice, we usually model support conditions that are a combination of fixed translations and free rotations, or vice versa. A very common boundary condition is called "pinned." A pinned support is a support that is not allowed to translate (fixed for translation) but is allowed to rotate freely about any axis (free for rotation).
To answer you specific questions, for an 8x8 post,
Pinned (free to rotate, not allowed to translate).
Depends on the bracket and attachment to the bracket, but treating as pinned (free to rotate, not allowed to translate) will usually be conservative.
Pinned (free to rotate, not allowed to translate) .
No
  • $\begingroup$ by pinned you mean fixed correct? $\endgroup$
    – RLZaleski
    Commented Mar 10, 2016 at 19:51
    $\begingroup$ @RLZaleski, Pinned is the name given to a specific support condition: no translation (fixed for $\delta_X$, $\delta_Y$ and $\delta_Z$), but allowing rotations (free for $\theta_X$, $\theta_Y$, $\theta_Z$). $\endgroup$
    – Wasabi
    Commented Mar 10, 2016 at 20:41
  • $\begingroup$ @wasabi, cant you have a pinned connection like at the end of a bridge where the girder is fixed for translation in all direction, free in rotation such that the girder can deflect in the vertical plane, but is fixed for rotation about the other two axis? in other words wouldn't you only need a minimum of one axis of rotation to be free for it to be considered pinned? $\endgroup$
    – Forward Ed
    Commented Jun 25, 2016 at 4:20
  • $\begingroup$ @ForwardEd: I think that's up to you, honestly. I personally would call such a connection "pinned around Y" or something of the sort. But sure, if you called it simply "pinned" I'd know exactly what you mean. $\endgroup$
    – Wasabi
    Commented Jun 25, 2016 at 16:27
