I don't have access to matlab right now, so plots that can illustrate my thinking will (if needed) follow later.
So what do we know? We know that the closed loop transfer function has 3 poles, 1 real pole and depending on K 2 complex conjugate poles. You now want to find the pole A † for that $\zeta=1$. This means we need to find a pole with no imaginary parts and negative real parts (for a stable system).
Now it seems like it is sufficient to look at an open loop transfer function, I assume this is due to the fact that you could calculate K later to find the gain of your closed loop transfer function to yield you the corresponding poles.
From
$s = -\zeta \omega_n \pm \omega_n \sqrt{1-\zeta^2}$ (I)
we yield $s = -\omega_n$ thus $\beta = \omega_n$
In order to get possible complex conjugate poles we need to have the form of $(s+\beta)^2$
There is an explanation which derives (I) from the fact that mostly these functions can be described with ODEs of order $n$ but I'm lacking the understanding to explain this to you so I'll just say this will have to do. I mainly apply these functions rather than deriving them. So bear with me.
$(s+\alpha)(s+\beta)^2=0$
Summing up we just let $(s+\alpha)$ be because we don't care for the poles of the left most part of the LHP because those poles always only have a real part as you can see from the root locus.
From the knowledge that $\zeta=1$ means no complex poles you can derive A.
And for the sake of completion: $\beta > 0$ or as the lecturer wrote $\beta$ cannot $\in 0 < \beta < 1$ comes from the knowledge that the system shall not be unstable.
† Why did you call A A'? Clearly A in the root locus is the point you are looking for.
