In this picture do we speak of (microscopic) plastic deformation if the edge dislocation has moved all the way to the right and emerges out of the surface? Or if you apply shear stress and stop when the edge dislocation has moved from A to B is it then plastically deformed aswell?
How about with this situation? Is it only plastically deformed when the dislocation line has moved all the way to the left and thus the screw dislocation emerging from the crystal?
Ow and one last small question: 'before and after the movement of a dislocation through some particular region of the crystal, the atomic arrangement is ordered and perfect; it is only during the passage of the extra half plane that the lattice structure is disrupted'
This particular region is that the region B to D, when the dislocation starts at A and moves untill emerges? And if the dislocation motion stops while the edge dislocation is at position B or C then this region isn't ordered and perfect? Because there is a linear defect in it?
