A well-known method to measure sheet resistance is the van der Pauw method. Looking at Wikipedia they state that the cloverleaf configuration is the most advised. Two questions naturally arise:
  1. Why is this the best configuration?
  2. Why is it a cloverleaf and not a fully "filled" circle?
As van der Pauw noted in his original paper, the incisions in the cloverleaf shape "substantially reduce the error due to the finite dimensions of the contacts" compared to simple circle. A cloverleaf is effectively a small central circular sample with four large contact pads, and you can be a little less precise in where connect to those pads.
According to Koon, to achieve resistivity measurements with 1% errors, a typical cloverleaf is about 4 times more forgiving than a simple circle for small displacements of the contact points on the edge of the sample. Even a simple square sample with contacts at the four corners is about 3 times more forgiving than a simple circle.
For 1% Hall coefficient measurements, the square is actually the best, being about 12 times more forgiving than the circle, while the cloverleaf is only about 7 times more forgiving.
