I need to figure out what type of steering does this 1:10 Himoto Buggy Zmoto Z-3 RC car have in order to be able to calculate the steering angle from servo position for a robotics project. Is it the same mechanism as Rack-And-Pinion steering?
I guess the steering angle change will not be constant (steering won't be linear) from servo since the rotational movement of servo is translated in the steering mechanism? I mean, whether one degree from 0 to +1 on servo will translate to the same steering angle change as for example step from +45 to +46 on servo. If not, what is the non-linear relationship there?
Here are pictures of the steering mechanism (more at the link above): enter image description here enter image description here enter image description here
  • $\begingroup$ These things are about universally better to be determined experimentally than calculated. Sizing measurement errors accumulate to a degree that make the results useless. Just apply a range of control values, measure resulting angles, compose into a look-up table, approximate values in between. $\endgroup$
    – SF.
    Commented Nov 29, 2017 at 16:06
The key feature is that the steering has Ackerman geometry
This means that the steering arms coming off the back of the hubs are connected to the steering linkage at a point inboard and behind the pivot point of the hub. If you draw a line through these two pivot points for both wheels they will meet at or near the centre of the rear axle (although the exact location may vary to produce specific handling characteristics).
The effect of this geometry is that, when turning the inside wheel will turn through a greater angle than the outside, reflecting the fact that the inside wheel follows a smaller turn radius. In a basic Ackerman geometry lines extending the axis of the front stub axles will meet at the centre of the turning radius, although again this may vary to suit particular handling characteristics.
It looks like the steering is controlled by a bell crank linkage rather than rack and pinion, so you may have to make some measurements to work out the precise relationship between servo position and steering input.
In practice there are also a lot of other related factors which affect the relationship between steering input and the actual behaviour of the vehicle as the steering geometry is also affected by suspension movement and the tracking, caster and camber angles of the wheels as well as the dynamic behaviour of the vehicle as a whole. This is particularly the case with something like an RC car which tends to have low mass and high torque so there may well be significant steering effects from factors like bump steer and roll steer, how the differential distributes torque to the rear wheels (ie the amount of slip in the differential and rear wheels) and the dynamic behaviour of the front tyres.
  • $\begingroup$ Thanks for answer. I plan to minimize the effects from suspension etc. by driving carefully at lower speeds indoors on a very flat surface and using only small steering angles (=big steering radius). I am still curious how the linkage from the servo shaft to the steering mechanism will behave - the rotational movement of servo may not be a huge problem (can be calculated easily) but I am rather concerned by the linkage that connects both right and left steering part together - shame that does not share the hinge with the links that go to the wheels, but the difference will probably be minimal. $\endgroup$
    – Kozuch
    Commented Feb 26, 2016 at 14:15
