First of all, I'm interested in train track only, not the rolling stock.
How are tracks built to cope with really cold weather? An example might be some place in Canada or Siberia. Ice would accumulate all the time, changing the shape of the rail.
How does the ballast or foundation cope with the thawing tundra in summer? What about the really nasty stuff like blizzards dumping snow over the track, or sleet, or freezing rain?
    $\begingroup$ you worry too much about ice and snow and not enough about the metal shrinking and expanding with temperature changes. Sleet is by no means the "really nasty stuff" if you're running a railway. $\endgroup$ Feb 21, 2016 at 16:34
    $\begingroup$ @KateGregory I already know how to handle thermal expansion/contraction. Use breather switches (expansion joints). What I don't know is how to handle the rail changing shape to due to ice buildup. That ice could come from rain, sleet, or really any precipitation. Water's volume expands 9% when freezing, and if it gets in the nooks of a railroad, it can crack it. $\endgroup$
    – DrZ214
    Feb 21, 2016 at 23:09
  • $\begingroup$ Were you asking about the brittle transition temperature of the steel ? $\endgroup$ May 8, 2018 at 13:09
  • $\begingroup$ @blacksmith37 Not really. If I'm not mistaken, there are different alloys of steel to stay non-brittle at different temp ranges. What I was really worried about was "frost heave". I just didn't know that term at the time. Another concern was how often does a snow plow need to run the track and how long that takes. $\endgroup$
    – DrZ214
    May 8, 2018 at 15:04
  • $\begingroup$ Rail steel is brittle at those temperatures. $\endgroup$ May 9, 2018 at 19:47
14
Precipitation
Snow
Snow can be a problem for running trains, but it really doesn't affect the rail/ballast. Just like on highways, the snow needs to be moved away, but it doesn't have many other effects.
Trains are used to plow through small amounts (Wikipedia):
and large amounts (Wikipedia):
Ice
Ice could cause more of an issue due to adding thickness to the rails. This is mostly handled by making the trains travel slower. The weight of the wheels on the rail is enough to crush through any ice that has accumulated, i.e. trains are really heavy. As long as the train doesn't move too fast, it isn't in danger of derailing.
Track Components
Switches
Switches need to move in order to operate. Ice and snow accumulations can cause issues if they keep the components from moving. It is for this reason that most switches have switch heaters installed. These are gas powered heaters that blow hot air in the appropriate locations to melt any snow or ice.
Rail
Like mentioned above, the rails aren't really affected by ice or snow. They are just chunks of metal. The biggest issue that rails face is the cold.
Rails are restrained by rail anchors from expanding and contracting due to temperature changes. If the weather gets cold enough, the rail won't be able to contract enough and the stress will be so great that the rail will break. This isn't as much of an issue as you might think though. Many sections of railroad use the individual rails to transmit signal controls. They are set up to failsafe, so that a broken rail is the same as a broken connection. This will show a stop signal.
Ties
Ties are hunks of wood. They aren't really affected.
Ballast and subgrade
As you mentioned, freeze and thaw will cause issues due to volume changes. These effects can be foreseen and dealt with.
The ballast section should be designed to drain water. If there is no water, there is less chance of volume changes. The same can be said for the subgrade. Drainage is key.
Apart from a good design, freezing and thawing happens every year. It is very predictable. During the time periods where these effects are likely to cause issues, the track can be inspected regularly to keep it in geometric tolerance.
  • $\begingroup$ For the rail, what about ice on the side of the rail? Doesnt this change the thickness and thus affect how the wheels run? $\endgroup$
    – DrZ214
    Feb 21, 2016 at 23:12
  • 4
    $\begingroup$ @DrZ214 It breaks off. Trains weigh a lot. It's all about going slow if there is a lot of ice (think first train of the commute for metros). After that, ice shouldn't be an issue. $\endgroup$
    – hazzey
    Feb 21, 2016 at 23:29
  • $\begingroup$ Both Ice and snow can be real problem for trains trying to get traction in the right / wrong conditions. I've been stuck on trains unable to run in both conditions but all it took was one train to get through to clear the tracks for following trains. $\endgroup$
    – Ian Turner
    May 8, 2018 at 15:41
  • $\begingroup$ @DrZ214 We had train tracks by our high school. We used to tape stacks of coins to it and come check afterwards. Like silly putty mashed into each other. We were told by teachers to stop. Something about shrapnel. We called them nickel-dimes or penny quarters. $\endgroup$
    – DKNguyen
    Oct 30, 2021 at 1:45
I was a hoghead for 25yrs here in the NW and we had a few real cold but not very many. Our main fear was water. If the tracks got under mined and you were the train to go over it when it decides to go, the rest of your trip isn't much fun. Whereas if the rail breaks during cold, the dispatcher will see that almost instantly. The undermined rail won't break until a car going over that spot. Whether it's the engine or a trailing car. Hopefully it goes on a trailing car. That way your train would separate and go into "emergency". And if the engineer "hoghead" knows what he's doing, you come to a smooth stop.
  • $\begingroup$ Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center. $\endgroup$
    – Community Bot
    Dec 25, 2022 at 5:31
