One of the valves on my 3 bar line just failed. Without it, our production has ground to a stop and we can't operate until we get a replacement (which we have already ordered). In order to make a deadline, I am trying to find a way to use a (properly rated for pressure) DN 16 flanged valve to fit with the existing DN 10 piping.
Is there any way to (safely) connect these two flanges together temporarily?
  • $\begingroup$ Can you find a flanged reducer? We use these all the time in our production plant. They especially are useful for changing the diameter of the line when installing fittings. $\endgroup$
    – tralston
    Jan 21 '15 at 6:07
  • $\begingroup$ @tralston don't have a proper one on hand / can't get one faster than the proper valve. $\endgroup$
    – jmac
    Jan 21 '15 at 6:58
  • $\begingroup$ @jmac if you cannot get a flanged reducer, are you able to connect your system via another pipe with different flanges on each side? $\endgroup$
    – smiddy84
    Jan 21 '15 at 8:12
  • $\begingroup$ Can you just Zeus it on with a weld? $\endgroup$
    – Inthebay
    Jan 27 '15 at 8:06
If you have access to a lathe you should be able to quickly machine a flanged reducer out of Nylon 6. Not sure what temperature you're operating at but make it a bit thick and it will easily be able to handle 3 bar.
