What is the down-stand beam called at an edge of a surface bed or raft foundation? It is not exactly a grade beam or stem wall. It is more like a toe.
What is the down stand beam called at an edge of a surface bed or raft foundation? It is not exactly a grade beam or stem wall. It is more like a toe.
This is probably a regional nomenclature thing, since I'm seeing quite a few ways for naming this. If you call it a grade beam, I don't think anyone will take it amiss.
Examples below of different ways of naming it.
Grade Beam
grade beam
(source)
Exterior Beam
exterior beam
(source)
Stem Wall or Thickened-Edge Slab
stem wall
(source)
Beam Strip
(source)
It is an "edge beam", or "grade beam", in a raft foundation, and a "downturn" of a slab-on-grade. The former is a structural component, usually spanning between columns, thus more massive and heavily reinforced. The latter is a strip footing or purposed to stiffen the slab edge and prevent outward migration of the subgrade.
