I need to have an electrical probe machined; but I am unsure how to specify my requirements. I am an electrical engineer with only moderate mechanical knowledge.
The probe will be machined from 0.125" diameter stainless steel round stock. The last 0.25 inch before the point necks down to a smaller diameter - maybe 0.031" - 0.062".
My question is in how to specify the pointed end of the probe. I want it to be sharp enough to dig in a little to the circuit under test but not so sharp that the point is fragile. Also, I don't want to specify overly-tight tolerances and push up the cost. I am assuming a Swiss screw type machine will be used.
What is "sharpness"? Is it the angle leading to the point or is it the diameter at the very end?
My initial stab at it would be something like: "a cone with 60 degree angle sides". But this seems to imply an infinitely small point.
Should I specify a flat end of a certain diameter? (i.e. a conical frustum instead of a cone?)
  • $\begingroup$ You specify a maximum round radius for the corner. $\endgroup$ Jan 30, 2016 at 19:51
  • $\begingroup$ How does radius-ing a corner apply to a point? What corner? $\endgroup$
    – PaulB
    Jan 31, 2016 at 22:48
Effective sharpness depends on both the angle of the cone and the geometry of the very edge/point. In this case it sounds like you aren't aiming for very deep penetration into the surface so the tip of the point itself is likely to be the key factor.
You also need to consider the ways that a sharp point wears. In general this can either be that material from the point is worn away, chipped or that the point becomes bent. This is a combination of the mechanical properties of the steel and the geometry of the point. Most sharp tools are heat treated and the precise temper is a crucial variable in tandem with the geometry in determining performance as creating a close approximation of a geometrically 'ideal' point or edge relies on controlling a combination of abrasive wear and plastic deformation which is not well catered for by conventional tolerancing.
In practice specifying the manufacturing process is probably more meaningful than geometric tolerances in the context of sharpness. Normally sharp edges are finished b y abrasive grinding and/or lapping and it may be the case that a manual finishing process makes the most sense.
In terms of the scale and overall geometry you are talking about there is an obvious parallel with sharpening the tungsten electrodes used in TIG welding and it may even be worth considering these as an easily available source of hard, small diameter rod, High speed steel and tungsten carbide are also possible contenders.
It would probably also be worth considering having the larger diameter part as a separate holder with a collet or similar to hold a replaceable probe tip. This arrangement would certainly be easier to manufacture than turning a small diameter neck in stainless.
For example you might specify that the point is sharpened to say 60 degrees and finished on a 1200 grit abrasive wheel. Also bear in mind that if you just specify that you want the tip sharp then sharpening things is something that any machinist should immediately grasp.
It may also be that you can find an off the shelf source of points as there are quite a few applications where these are used, carbide tipped scribers immediately spring to mind.
Also as general advice if you are designing something out of your specific expertise and experience it is always worth talking to whoever is going to make it and telling them what you actually want the part to achieve.
  • $\begingroup$ Thanks. The info about hardening is helpful. You may be over estimating how sharp I need the point. I fear extra manual steps you suggest would be cost prohibitive. Ordinary wood screws are plenty sharp enough for my purposes - and I doubt that they require any special processing. As for something off-shelf it would be difficult find anything with exactly the diameter and approximate length I require - I already spent about 20 hours on the internet looking :) $\endgroup$
    – PaulB
    Jan 29, 2016 at 19:26
  • $\begingroup$ It not just about ultimate sharpness but the durability of the point for example wood screws often have a slight burr on the tip which makes them initially very sharp but quickly breaks off. I would also say that manual sharpening may not necessarily be more expensive eg if I sharpen a scribe on an abrasive wheel it takes maybe 10 seconds, to do that on a lathe would be a major task. As to finding parts would a TIG tungsten work for your application ? The smallest standard size is 0.04" $\endgroup$ Jan 29, 2016 at 19:34
  • $\begingroup$ I took a quick look at TIG electrodes - they do come in 0.125 diameter (7" is way too long; but they could be cut, I guess.) Do they come in other materials besides tungsten? They seem expensive; I really need the cost under "$1", preferably under "$0.50". $\endgroup$
    – PaulB
    Jan 29, 2016 at 20:00
  • $\begingroup$ I would suggest that to reduce costs you set a short length of the tip material in a holder, a bit like clutch pencil or pin vice as it is a lot easier to drill an axial hole in a rod than to machine a necked point from a solid bar. TIG electrodes are ll tungsten but HSS drill rod has similar mechanical properties but is less resistant to corrosion. $\endgroup$ Jan 29, 2016 at 20:11
  • $\begingroup$ I'm not sure I understand the solution you are proposing. Would the smaller diameter piece be pressed into a 0.125" piece? $\endgroup$
    – PaulB
    Jan 29, 2016 at 20:24
Comments:
  • Do not specify manufacturing methods; what method is used is best decided by the shop depending on what tools they have and what they want to do with the job; the number of parts ordered will have a big effect on their approach. In general, you should never try to tell a machine shop how to do their job, because they know MUCH more than you do about what is practical and efficient.
  • In this case the dimensions are non-critical, so do not specify them. The tapered end of the probe is probably fine 0.25±0.05"
  • For the point, give them a sample of the material it needs to penetrate: "Sufficiently sharp to penetrate sample material annexed." They will figure out what needs to be done based on that.
For this type of job, I would expect a swaging machine to be used, assuming the parts are being made in quantity. Of course, if you go to a shop that does not have a swaging machine, then they will use some other approach, or they will buy a swaging machine if the order is big enough. There is also a special kind of machine called a "pointing machine" which would be another possibility.
  • $\begingroup$ My quantities are not huge - about 1000 to start. Would swaging require a custom tool? $\endgroup$
    – PaulB
    Jan 31, 2016 at 22:53
