I'm a beginner at autodesk inventor.
For some instances when I click a region to extrude it doesn't come alone.
The screenshot below illustrates something even stranger.
What should I do to make this not to happen?
9
In a sketch, you cannot have two lines that intersect themselves. You have to split them with the Split tool.
Your bottom line for example, must be divided into 10 parts.
  • $\begingroup$ Just to clarify: this is true only when extruding or doing other specific operations, correct? In general a sketch is valid even if it has intersecting lines? $\endgroup$
    – Ethan48
    Jan 31 '16 at 16:29
  • $\begingroup$ To extrude, revolve, sweep... you need a closed profile if you want to create a solid. To create a surface, all profiles can be used. $\endgroup$
    – Maxence
    Jan 31 '16 at 17:24
