I have an issue with simulink, basically it's to do with a second order system, well two first order systems in series. As I understand it as you increase the damping factor (above 1), the system should respond slower and be more sluggish. The damping factor = (tau1+tau2)/(2root(tau1*tau2)). So, looking at this system with damping factor 1(with it's response):
and this system with damping factor 1.19 and it's response:
What gives?! The system with the damping factor 1 hasn't even reached steady state by 250 secs while the system with damping factor 1.19 has had a faster response, why is this happening?
Thanks for reading.
