I've been designing an electric skateboard which is driven by only one of the rear wheels (for the moment). As I was picking out motors for the board, I soon realized I would need to find a balance between torque needed to climb hills, and RPM to get a good top speed.
So I'm searching for the best KV (RPM/v) motor/gearing ratio combination.
For all calculations I've assumed the following:
  • Total mass (board + rider) = 85 kg
  • Voltage = 12 Cells * 3.2V (LiFePo4) = 38.4 V
  • Max Speed = 40 km/h = 11.11 m/s
  • Hill Grade = 15%
  • Coefficient of friction between rubber and asphalt: 0.65
  • Diameter of wheel = 80 mm
I tried assuming maximum kinetic energy as being equal to maximum gravitational potential energy at the top of the hill.
$$E_{k,max} = \frac{1}{2}mv_{max}^2 = E_g = mgh_{max}$$
Then solving for $h$.
I'd take that and use $y/x = 0.2$, solve for $x$, then use some trigonometry to setup a Newton's Second Law problem and solve for force needed to overcome friction and gravity (Equilibrium problem).
Then using $T = F \times r$, find torque needed at the wheels, assume some gearing ratio that keeps that and the $V_{max}$. Then solve for RPM and divide by total voltage for motor KV.
My mechanics are rather rusty and I could use some help.
  • $\begingroup$ you can use your formula to figure out how much energy you are going to pull from the battery. For force&power look at answers below. $\endgroup$ – jumpjack Mar 6 '20 at 14:13
11
I think you're overcomplicating things. To push 85 kg up a 15% slope against gravity of 9.8 m/s2 requires a force of
$$ \sin (\arctan (0.15) ) = 0.1483 \approx 0.15 $$
$$F = 85 kg \cdot 9.8 \frac{m}{s^2} \cdot 0.15 = 125 N$$
With an 80 mm wheel, this requires a torque of
$$T = 125 N \cdot 0.04 m = 5 Nm$$
To do this at a forward speed of 11.11 m/s requires a fair amount of power:
$$P = Force \cdot Velocity = 125 N \cdot 11.11 \frac{m}{s} = 1400 W$$
which is about 36 A from your 38.4 V battery pack, and your wheels will be turning at
$$\frac{11.11 \frac{m}{s}}{\pi\cdot 0.08 \frac{m}{rev}} \cdot 60 \frac{sec}{min} = 2600 RPM$$
Does any of this help you move forward?
  • $\begingroup$ Thanks a bunch, I think I got on one pattern of thinking and found it hard to go back! This is what I'm looking for. $\endgroup$ – Satchel Jan 4 '16 at 5:39
    $\begingroup$ The calculation of force should be $F=m \, g\, \sin{\theta}$. In this case, $\sin(\tan^{-1}0.15) \approx 0.15$, so it works, but that's not the general case. $\endgroup$ – Carlton Jan 4 '16 at 13:18
  • $\begingroup$ @Carlton: Do you understand that we're just doing some ballpark estimation here? Small-angle approximations are perfectly acceptable. $\endgroup$ – Dave Tweed Jan 4 '16 at 13:46
    $\begingroup$ @DaveTweed - While I would agree that small-angle approximations are acceptable, OP's "mechanics are rather rusty", and you didn't state/show that you were using any small-angle approximations. $\endgroup$ – Chuck Jan 4 '16 at 13:48
  • $\begingroup$ @Chuck thanks for the concern, I did pick up on that however I just assumed that he did that calculation and rounded off to 0.15 $\endgroup$ – Satchel Jan 4 '16 at 19:24
The answer provided by Dave is correct but it covers only a very specific case of no-friction and constant speed. There are three forces acting on a vechicle which must be accelerated from 0 to v speed over a slope:
Cr is the rolling friction coefficient, around 0.01 for cars on asphalt, so probably something less for bikes. Don't know for skateboards, but they have forul large&flat wheels, so maybe it's more similar to car coefficient than bike coefficient.
Being it a skateboard over a slope, it has a very slow speed, so we can neglect air drag, but for a generic vehicle you must also take it into account:
$$ F_D = \frac 1 2 \rho C_D A v^2 $$
$$ \rho = air density = 1.22 kg/m3 $$ $$ C_D = \text{drag coefficient (around 0.8 for bike/human, 0.2-0.3 for cars)}$$ $$ A = \text{Section area or Frontal area, m2}$$ $$v = \text{speed, m/s}$$
Inertia force resists to acceleration.
I found a calculator: it's designed for robots, so it disregards both wheel and air drags:
https://www.robotshop.com/community/blog/show/drive-motor-sizing-tool
This is a much more complex&complete simulator, but I don't understand how to input custom data for motor:
https://vesc-project.com/calculators
