I am studying the performance of volumetric solar receivers (specifically ceramic foams) versus the change of many parameters: solar flux, surface temperature, porosity, pore diameter, flow pressure and flow velocity. I have seen two ways in the literature to model porous media:
- Drawing a complex 3D structure that is analogous to the porous zone.
While this might be a very-problem-specific solution, but turbulence modelling in that case is not a problem.
- Averaging the governing partial differential equations to account for the nature of porous media and introducing new terms to the equations (porosity $\epsilon$ and superficial velocity).
And this is the approach I am taking which is used in porous models in many CFD solvers.
However, while reading about the treatment of turbulence in porous media in the FLUENT user guide I found that turbulence is not exactly modelled:
turbulence in the medium is treated as though the solid medium has no effect on the turbulence generation or dissipation rates. This assumption may be reasonable if the medium's permeability is quite large and the geometric scale of the medium does not interact with the scale of the turbulent eddies. In other instances, however, you may want to suppress the effect of turbulence in the medium.
I find "medium's permeability is quite large" quite ambiguous (What values are considered large?) and don't know whether my model will be badly affected by this treatment or not and to what extent?
So has anyone came through this before? or am I overcomplicating things for a parametric study?
