When you compress a bicycle pump and seal the opening, the pump will automatically return to it's initial position when you release it. I suppose this is how air suspension works as well?
if you have a internal combustion engine without any gas and turn it over - for instance with a kickstarter, until the piston reaches the very top on the compression cycle - why doesn't it return to the bottom by itself by the air compression alone? Is there anything blocking this, or is the air simply not powerful enough to turn the engine over?
See comments from Physics StackExchange
