Are there any free online databases where I can access data for the wear rates of materials? I tried using CES EduPack, but I'm having no luck.
Maybe other free and open databases are also existing on the net? Where and how could I find the wear rate in them?
    $\begingroup$ Welcome to engineering SE. Do you have any particular material of interest? $\endgroup$ Commented Nov 18, 2015 at 12:00
  • $\begingroup$ Wear rate will depend heavily on application. $\endgroup$
    – mart
    Commented Jan 28, 2016 at 13:09
Maybe you should check out tribology. There is such thing as specific wear rate, k, for example, which is given for a pair of materials in dynamic contact. Say steel over steel has very low coefficient, even better than PTFE over steel, for example.
