I'm building a rotary inverted pendulum to demonstrate reinforcement learning principles, however I have little experience with mechatronics. I will be building something similar to this.
However instead of plastic I will be using 10 mm aluminum tubes. The arm (horizontal) will be about 150mm long and the pendulum (vertical) will be about 150mm to 200mm with a little weight at the end (a few hundered grams).
So I have started my construction but the problem I have now is choosing a motor. I started looking through sparkfun and some chinese stores for motors until I realised that I have no idea what type or how powerful of a motor I need.
In order to avoid the complex calculations, I was hoping someone could give me a ball park estimation of the torque I would need, and the best type of motor for this application (stepper or a classic DC motor) considering my setup?
This site is temporarily in read-only mode and not accepting new answers.
Browse other questions tagged .
