I am trying to create two paddled wheels overlapping each other alternately. Figure looks something like this.
And the rotation phases would be like:
Since the position of those paddles are a little bit off, though I'm not an engineer of anything, I knew the balance will also a bit off. Correct me if I'm wrong.
What I am thinking is to add additional paddle of maybe 1/3 of the 3 main paddles
. I want it shorter since I don't want it to get involve in the interactions of 3 main paddles between those 2 wheels. This will serve as a compensation to balance out the rotation of the wheels.
Can anyone give me a formula to calculate where should I put the compensation paddle
and the length & weight of it to balance out everything?
PS: I'm not an engineer of anything so I'm not sure if this design is possible and will work in the real world. I am just trying to experiment with something.
EDIT: These are the problems that I wanted to be solve:
1. Unbalanced Mass Distribution: If the paddles are not evenly spaced or are angled differently, they can cause an imbalance. This imbalance can lead to vibrations, uneven wear, or strain on the wheel and its bearings.
2. Centrifugal Force: When a wheel rotates, the centrifugal force acts on the paddles. If the paddles are at different angles, the forces might not be evenly distributed, potentially causing wobbling or instability.
3. Torque Imbalance: Paddles at different angles can create varying amounts of torque as the wheel rotates. This could affect the performance of the wheel and any attached mechanisms, particularly if precision is important.
4. Dynamic Imbalance: As the wheel rotates, any imbalance in paddle positioning can result in dynamic imbalances, leading to further issues like shaking or difficulty in maintaining a steady rotation.
Possible Solution: Implementing Compensating Paddles
- Placement:
- Opposite Main Paddles: Place compensating paddles directly opposite the main paddles. This helps balance the wheel by distributing forces evenly.
- Calculated Positions: Alternatively, place them at specific angles based on the main paddles' positions. For example, if the main paddles are at 0°, 120°, and 250°, place compensating paddles at angles where they can effectively counterbalance the forces.
- Length and Size:
- Short Length: Making them shorter ensures they do not interfere with the operation of the main paddles. Their primary function is to add balance rather than interact with the main components.
- Weight: Ensure the weight of the compensating paddles is sufficient to counterbalance the imbalances but not so large that it affects the overall performance of the wheel.
Sample figure with compensating paddles:
How can I calculate for the position, length and weight of compensating paddles?
