Back story: I am trying to make my attic (where I have my home office) comfortable during heat waves. I live in the Paris area, where heat waves are comparatively dry (in fact, they are the only time when it is comparatively dry).
So, I decided to get a medium-sized evaporative cooler ("swamp cooler"): https://www.amazon.fr/KLARSTEIN-Skyscraper-Rafraîchisseur-Humidificateur-Refroidisseur/dp/B085HM8N2Z?th=1
It does produce a cool breeze, so I suppose it is helpful if you stand or sit literally in front of it and quite close to it. I didn't notice enough of an effect if sitting at 1-2m from it.
So, wanting to determine the truth, I ran an experiment.
My attic consists of two compartments (not counting the bathroom): I closed the windows in both, and ran the evaporative cooler in one of them; I put a thermometer/hygrometer in each compartment. After a while,
- the half without the cooler was at 30.9 C, 50% humidity,
- the half with the cooler was at 30.9 C, 60% humidity. That's a remarkably total and precise failure! The cooler was humidifying without cooling. My question is: how is this even possible?
Wouldn't just about anything (indoor fountain? cat in cold bathtub?) do better than this? How can a tool manage to be so bad? How do you set out to make an evaporative cooler that doesn't work?
Further details
Some data (from https://www.kwangu.com/work/psychrometric.htm): 30.9 C at 50% corresponds to a wet-bulb temperature of just 22.75 C (i.e., we could be very comfortable if were just willing to do math while wrapped in wet towels). An evaporative cooler that keeps enthalpy constant (I thought that was a reasonable assumption - these are low-powered devices, so the heat they dissipate by operating is likely negligible) would keep wet-bulb temperature constant. Then, at 60% humidity, we would have expected the temperature to be lowered to 28.7C, a significant change.)
I ran the experiment again the following day. Starting conditions (at 4:50pm): outside temperature 28C, attic room with cooler: 32.8C, 42% humidity; attic room without cooler, 32.9C, 47% humidity.
End conditions (at 11:25: attic room with cooler - 30.3C, 60%, attic room without cooler - 31.2C, 51%). All right, this time, the cooler did something, but it seems to be remarkably bad at what it does. What does the effectivity of a cooler depend on? Is the performance of this one typical, or is it particularly bad?
(Further information: yes, the attic is reasonably well-insulated - I had the side walls insulated myself. Ceiling insulation was done by the previous owner, presumably to the standards of about 15 or 20 years ago; there is about 15cm worth of it. There are plenty of (double-glazed) skylights, but they are covered by outside shades in this season (the shades are partly see-through but pretty effective; you do not want to know what it was like before I got them). The roof is clay tiles.)
