I would like to know what mechanical parts can be used to convert a rotation movement from an axis to another.
For example: You have the shaft of a motor rotating vertically, but you need to rotate a part horizontally.
I already found the worm drive assembly but I would like to know if an "exhaustive" list exists somewhere with pro/con for each.
The go-to solution is bevel gears. They are used when the shafts would intersect and allow the same ratios as normal gears.
You can also make one of the gears a crown gear so the other gear can be a normal spur gear.
A universal joint is also an option if the angle isn't too big.
  • $\begingroup$ Are there existing belt based solutions ? I'm a little bit worried by backlash that could be added by bevel gears. $\endgroup$
    – LiohAu
    Nov 7 '15 at 21:47
  • $\begingroup$ There is backlash in belts too as the tension is transfered to the other side of the belt. But you can use cones as friction gears. $\endgroup$ Nov 7 '15 at 22:14
