I don't typically post to engineering but I need help with a USB drive. First off, I have a USB, a Sahara 128mb, that once became unusable on windows machines, and I thought it was dead. Yet I kept it for about 10 or more years to-date. Recently, I plugged it into a linux machine and I saw magic, it worked. I never changed the filesystem types, or anything.
Now, I have a newer SanDisk 16GB USB that I actually did nothing to except try to flash an OS onto it and it failed on its own. It has two partitions, one already has another OS written to it. I am not sure if the disk was burnt during the write of the second OS. This was a normal write by something like rufus/unetbootin (which might matter, as that could be the culprit). But now, most operations on the USB will return an IO error. I can read and actually use (boot from the USB) the first partition to install that OS. But when I try to delete the data on the USB, or the first partition, it fails and automatically ejects.
The second partition has a newer version of an/the OS I wish to write to the disk/partition. Initially, it allowed me to delete the files on the disk but once reaching a certain point, the writes fail and it ejects itself. My problem is that everything seems intact. I do not know how the disk was locked or became write protected. I tried a few utilities to remove this, and it seems to respond but nothing has changed.
I read about MBR and GPT, and there is a clue there. When the GPT is present or readable via gdisk, my partitions are intact, when both are present, MBR shows nothing and the GPT table is intact. So the clue is a mismatch of some sort. And regardless, the data is intact. I had another HDD 500GB disk (probably SAMSUNG) do a similar thing, I was doing 'nothing' for hours, then I ran gdisk with disks utility side by side, and started to see the changes I was making to my disk.
It turns out that with the HDD disk, I was doing what I wanted to do but gdisk was throwing gang signs, claiming that my operations failed. Once I caught this, I fixed it, and stopped working blindly.
Unfortunately, when my disk was mismatched again, on the SanDisk USB that prompted me to open this question... I tried a similar thing or solution as that which helped me with the other HDD disk. I can for example see the partition deletion take place, but before it is committed the USB disk fails with an IO error, and ejects itself. So, when it is inserted again, it is as if I never actually did a thing. So now the operations are failing.
Any ideas on how I can fix my disk? At this point, I wish to even suspect the tools that I am working with. The disk is readable on windows very briefly but any attempt to access its data or perform administrative disk utility operations causes it to eject. Windows is not very descriptive. I suspect that it is fried, can this theory be tested, or how do you test for a fried USB, when it seems or appears to be working? And, how do you just nuke the USB disk to a factory state? I think that once I do that I will be able to separate healthy sectors from dead/corrupted ones. I will not miss the data on it at this point, as it is easy enough to loan an ISO from a friend or download it from the internet and write it to the disk again.
This will be a very important lesson for me in disk management, especially if I can develop a true method to test for dead drives, rather than ones not being supported by my system. Though this could very well be one and the same thing.
I hope engineers will help. There was no need to re-post Linux commands, you know them, I probably read them off a reference manual, on stack overflow, or someplace else on the internet.
Reference: something like what this person wanted https://www.vbforums.com/showthread.php?613245-how-to-fry-a-flash-drive or gravitating towards the level of work suggested. There are many references to switching OS, as different ones have different capabilities for manipulating hardware for obvious reasons, hardware is expensive. I don't wish to fry it, just reset with no regard for data, if manipulating data pins can help, I wish to learn that, and research safety of the procedure.
8
    $\begingroup$ There was no need to repost linux commands, you know them ... that is not a very useful description of what you did $\endgroup$
    – jsotola
    Commented May 9 at 1:04
  • $\begingroup$ If a flash drive starts working erratically, there might be a bad connection inside. Hardware problems are "hard" to solve in software. $\endgroup$ Commented May 9 at 2:05
  • $\begingroup$ Wipe the whole disk by running a destructive check for badblocks. Once you get back the report of which blocks failed, you should have a better understanding of why. $\endgroup$
    – Abel
    Commented May 9 at 3:57
    $\begingroup$ Can you please break this question up into paragraphs to make it more readable? $\endgroup$ Commented May 9 at 8:43
  • $\begingroup$ Update: I made an attempt to delete data using a TV, and it claimed "unknown service" after successfully reading all data, and even displaying contents of text files. This was incase linux software was the limitation. Anyway, TV software respects the partition table/disk layout, and even corruption. Any other suggestions? I am willing to try short-circuit memory chips on the USB if anyone knows the schemas for San-disk as well as 'safe voltages'. Kind of like BIOS resets on old PC motherboards. $\endgroup$
    – Phume
    Commented May 17 at 20:37
You can use the Windows command line utility diskpart. Read the documentation carefully as it can cause loss of data if you don't identify the drive you want to work on correctly. It can make you lose all your data and make your computer unbootable.
That said, the "clean" command will remove all partitions, GPT/MBR IDs and formatting from a USB. If you then remove and reinsert the USB, Windows will see it as completely new, and ask to format it.
I use this regularly to refresh USBs that have been used as bootable installation disks where multiple partitions have been created e.g. Linux installs, Memtest86 live disks, gparted live disks etc. Some of these disks become unrecognised in Windows and require diskpart to recover them.
I prefer Windows utilities for these tasks, as there is a higher chance of success than using linux utilities if the end goal is to use the USB on a Windows machine.
  • $\begingroup$ Not quite right, it does not show up on "list disk". $\endgroup$
    – Phume
    Commented May 12 at 13:44
