As mentioned in the question, I am looking for a method to attach this mounting bracket to the flange of a steel beam that permits effortless removal and remounting without permanent fixation.
Picture ist the side that needs to be mounted
  • $\begingroup$ clamps with bolts or just bolts. $\endgroup$
    Apr 3 at 11:16
  • $\begingroup$ "Effortless"? Really? $\endgroup$
    – Transistor
    Apr 3 at 12:13
  • $\begingroup$ Or a switchable mag-mount such as used on drills etc but without any use or loads who knows... $\endgroup$
    Apr 3 at 12:37
  • $\begingroup$ effortless removal and remounting of what, the plate, or something attached to the plate? $\endgroup$
    – jsotola
    Apr 3 at 15:21
  • $\begingroup$ What loads must it withstand while mounted? How effortless do you consider those "command strips" for mounting things to a wall? $\endgroup$
    – Abel
    Apr 4 at 2:43
