12
Magnetic locks seem to be fairly common on the doors of modern buildings, but I question their reliability when compared to a traditional, mechanical lock. I realize that the strength that it would take to actually pry a door away from a good electromagnetic lock would certainly be enough to damage the door or frame, just as it would be with a mechanical lock.
If you had an electromagnet strong enough, however, wouldn't it be possible to negate a magnetic lock by fastening your oppositely-polarized electromagnet on the outside of the door opposite the magnet on the inside so that, when activated, the outer magnet would overpower the attraction between the inner magnet and the magnetic material on the door, effectively opening the locked door?
If so, I feel this would be a pretty big disadvantage when compared to a traditional mechanical lock. Not that a powerful and portable electromagnet is necessarily a readily available and affordable thing, but...
Ignoring the practicality of actually owning and operating such a powerful electromagnet, is this even a plausible thing to do?
8
    $\begingroup$ I don't think would be thieves would find hauling around sufficiently large electromagnets to be particularly practical. $\endgroup$
    – Paul
    Nov 4, 2015 at 5:16
  • $\begingroup$ Right. And that makes sense. I guess I'm willing to throw out the practicality of it; just want to know if it's even possible, or if there's some reason that it wouldn't work. $\endgroup$ Nov 4, 2015 at 5:21
    $\begingroup$ Can't say I agree with "the strength that it would take to actually pry a door away from it's electromagnetic lock would be enough to completely destroy the door" - my halls at university used electromagnetic locks, and they could be opened by yanking sufficiently hard on the door handle. (Notes: there are probably better made electromagnetic door systems available. This one had an electromagnet at the top. By yanking on the handle in the middle of the door, I suspect prying was important in our ability to overcome the magnet, rather than just normal force). $\endgroup$
    – AndyT
    Nov 4, 2015 at 9:05
  • $\begingroup$ @AndyT yeah, that makes sense. So maybe "completely destroy" is going too far, but certainly it would damage the door and potentially the frame as well. Even leaving the doors propped open can be bad for the system, because when the frame tries to engage the magnetic locks again, it warps the frame. $\endgroup$ Nov 4, 2015 at 15:11
    $\begingroup$ A neodymium magnet of some 0.5kg would provide magnetic field as strong as the door electromagnet, from a distance equal to door frame thickness. Though it would create other problems... transporting these things is not an easy task, easily ranging between comedy and tragedy. $\endgroup$
    – SF.
    Dec 21, 2015 at 12:28
3 Answers 3
9
I think it may be possible but more difficult than it first appears.
I don't know this, but I suspect that the three poles are arranged as south-north-south (or vice-versa) and that the coil is wound, pushed into the black slots and potted in position. Once the (electro) magnet hits the keeper the magnetic circuit is closed. As anyone who has played with a horseshoe magnet will know, opening the closed loop is very difficult. Interfering with this closed circuit from outside would be very difficult due to the relatively low permeability of the air relative to the iron. Iron is about 5,000 times more permeable than air.
Here we can see that with the lock open the exposed faces are poles of the electro-magnet. Note also that the magnetic path is twice as wide in the centre pole as on the upper and lower poles so that flux density is fairly constant. Once the lock closes the flux forms a loop through the iron core.
I would think magnetic cancellation is unlikely to be practical.
  • $\begingroup$ Excellent answer. I wasn't thinking about different strips of differently-polarized magnets, but of course that's how it'd work; that seems to complicate the problem enough for security. Thank you! $\endgroup$ Dec 21, 2015 at 15:21
    $\begingroup$ It's even better than strips of differently-polarized magnets - it's the opposite ends of the same magnet - hence my horseshoe magnet analogy. $\endgroup$
    – Transistor
    Dec 21, 2015 at 22:27
  • $\begingroup$ Ah gotcha. That helps be to better understand what's going on here. Thank you. $\endgroup$ Dec 21, 2015 at 23:02
Yes you can negate or deguass an electronic magnet actively. The older door electromagnetic locks uses permanent magnets and electromagnets hybrid called bonded magnets. The magnet is locked when the power is turned off allowing the permanent magnet to stick. When electricity is applied it creates a field that to temporarily neutralize the permanent magnet allowing it to release so when the power goes out the default is locked like in an insane-asylum . While the door is propped open some one can easily depolarize or degauss the permanent magnet side by walking by and holding a much stronger magnet north to north or south to south quickly and permanently weakening the door's permanent magnet strength.
A lot of the responses here are very interesting but the inverse relation of magnetic fields and magnetic strength must be considered. if two attracting magnets are a certain distance apart (say 1 inch) their attraction is for example 2lb. if the two magnets are 1/2 inch apart their attractive force is 4lbs and a quarter inch 16 pounds. all simplified numbers. In a magnetic lock, the two units are touching and therefore very strong. any external magnetic force applied to the outside of a door would be the thickness of the door (plus a little) away from the electromagnet. to overcome a mid-range magnet of 800lbf you would need a much much larger electromagnet (exponential). this seems to be as much of a physics question as an engineering question. If you have an hour, this guy is very engaging and demystifies magnets and electromagnets in one shot. it is filmed 10 years ago at UC Berkley but is meant to be understood by the likes of me so that is saying a lot...
https://www.youtube.com/watch?v=WxitGR-9qGA
