When we calculate the bending moment in a beam with a fixed end using the the method of cuts (determining the moment at a point $x$ by making a cut at that point in the beam) we usually include the restoring moment as a moment about $x$ in the calculations.
For example for a simple cantilever with a point load at the free end. It has a restoring moment $R=Fl$ at the support and vertical reaction at the supports of $A_y$:
$R-A_yx-M_x=0$ would be my moments about $x$. Why do we include the reaction moment $R$ when it acts about the support of the beam and not the point $x$?r
Do these moments actually act on a different point than I assume or is the fixed end moment caused by some sort of couple?
Note that the restoring moment, or technically the fixed end moment, represents the total energy produced by the applied force at a distance"x = l" from the support (which is the point of x = 0). And, for any point along the beam, to maintain structural equilibrium, the sum of forces must be equal to zero, that is, 0 = the total energy (R) - the energy produced by the reaction (Ay) and the internal energy (Mx) at that location. It is depicted in the figure below. Hope this helps.
