This is a question that has been haunting me my entire career. The pressure loss caused by friction is not the same as the pressure "loss" caused by vacuum, right?
I mean, if I have a gas flowing though a pipe, the more restricted the way is, the bigger is the pressure drop caused by the pipe and therefore it should be more difficult for me to push the gas through said pipe.
Maybe the best way to put it is: what is the difference between a 2000 Pa pressure drop caused by friction compared to using a pump to pull a gas with a suction pressure of -2000 Pa? Why does one of them block my gas flow and the other helps it flowing?
Thanks in advance, this question drives me crazy
