I am working with FreeCAD 0.20 and Sheet Metal work bench 0.2.63, but universal CAD tips are also welcomed. As shown in the image, I would like to bend sheet metal with smoothly chancing width along the bend. So, I cannot use for example negative extend values causing stair-like features, unless the sharp transitions could be smoothed somehow afterwards. Any ideas?
Edit: I also tried the Sketch On Sheet metal tool, but it removes material appropriately only if the sketched cuts are fully within the sheet. If the cuts go over the edges the cuts become erratic.
