I am trying to calculate the final pressure and temperature in the pressure regulator and connecting line of a gas cylinder when the valve is open to pressurize the line.
The type of process across the regulator is Joule Thompson or isenthalpic ($\Delta h=0$) expansion. An ideal gas has zero temperature change during this process, but any real gas will have such a change, determined by its Joule Thompson coefficient.
In addition, if it is a closed system you are also compressing and heating the gas already in the line, which often overwhelms any JT cooling effect.
It is not a trivial problem you are trying to solve. My advice is do a test with a temperature probe if you're able.
Yes, mechanical work is done. This is similar to mechanical work done by a balloon when you untie the knot and let the balloon fly all over the place. Or similar to a water rocket. Except in a water rocket the ejected media is water, much denser than air but the concept is the same: gas pressure in a container ejecting some gas or liquid through some orifice.
The Bernoulli flow equation, Q is:
$$Q= C_AA\sqrt{2gh}$$
  • g is the gravity acceleration.
  • h is the difference between the tank's pressure and ambient pressure.
The momentary work is: $$dW=\dot Q P$$ $$P = P_{contaner}-P_{atm}$$
You need the Volume of the container and Ca and P container tp get the total work.
