What should I google to find the strap from the picture? It looks like a screw is used to tension the strap, which is exactly what I need. I've already spent some time trying to find a manufacturer who could supply these, yet unsuccessfully and I would appreciate your help!
Thanks!
I would go to a saddlemaker as they are good with leather, but a barrel maker may be a possibility, however there are few around now.
However, the parts may need sourcing but as a basic idea it is just a threaded rod and a nut - shaped etc so as to not damage the leather.
  • $\begingroup$ Thank you! However, I think that these are polyester webbing straps? $\endgroup$
    – slm992
    Jan 11 at 13:05
  • $\begingroup$ Well, difficult to tell from the poor image. $\endgroup$
    Jan 11 at 13:41
  • $\begingroup$ In that case, the straps can be seen in the following video: youtu.be/CkqhSfsFxhg?t=84 $\endgroup$
    – slm992
    Jan 12 at 11:59
The mechanism that tensions the strap looks like maybe a draw latch, though it's a little hard to tell.
Some examples of this mechanism: https://www.mcmaster.com/products/draw-latches/
