I have a problem, where I'm trying to solve the mass balance of a multi-step process with limited information available.
What I have is a material supply of known flow and composition. This supply is split into multiple streams (in my current case 7). For these streams, I do not know the individual flows, I only know they are not all equal.
Each of these streams is supplied to a separation process where they are separated into a product and a waste stream. I know the composition of each of those product and waste streams, bot no flows at all.
As such, the system looks like this: Process layout
From the compositions, I can easily calculate the ratio of product and waste stream for each separation process (i.e. the values of x1 ~ x7 above).
My problem is that I can't figure out how to calculate each of the process flows 1 through 7, or whether or not this is even possible with the information available.
I know that if I can set up a system of linear equations, where I have the same number of independant equations as unknowns, then it can easily be solved. However, I seem to only have 1 equation with 7 unknowns (sum of all process flows = total supply flow).
I would appreciate any help here.
  • $\begingroup$ you can't get there from here $\endgroup$
    – Tiger Guy
    Commented Jan 8 at 13:56
  • $\begingroup$ Thanks @Tiger Guy, after several failed attempts I came to the same conclusion. In the end, I had to gather some more data and then I could create a solver scenario in Excel, which performs some iterative guess work until the mass balance is correct. $\endgroup$ Commented Jan 9 at 17:06
  • $\begingroup$ If there is equal division of Feed or Feed split is specified...then it is is easy to perform calculations using system of linear equations $\endgroup$ Commented Feb 21 at 14:19
