When the system is first order:
$1/(1+s\tau)$
Why is the bandwidth: $f_{-3db}=1/(2\pi \tau)$?
Where did the $2\pi$ come from? Why isn't it simply $1/\tau$? The unit of $2\pi$ is related to radian. But the unit of $f_{-3db}$ is $[1/second]$ so unit of $1/(2\pi\tau)$ does not seem to equate to Hz
Unit of frequency is not really $1/\mathrm{second}$.
$$ 1\mathrm{Hz} = 1 \frac{\mathrm{cycle}}{\mathrm{second}}=360\frac{\mathrm{degrees}}{\mathrm{second}}=2\pi\frac{\mathrm{radians}}{\mathrm{second}} $$
cycle, degrees, radians are kind of unitless since they all represent a fraction of a whole.
The unit of radians is kind of unitless since angle in radians is found by $\frac{\mathrm{arc length}}{\mathrm{radius}}$
Natural unit of frequency is radian/s. $$ \left|\frac{1}{1+s_{\text{(-3 dB)}}\tau}\right| = \frac{1}{\sqrt2}\\ \implies 1+\omega_{\text{(-3 dB)}}^2\tau^2=2 \qquad (\text{letting }s = j \omega)\\ \implies \omega_{\text{(-3 dB)}} = \frac{1}{\tau} $$ whre $\omega_{\text{(-3 dB)}}$ is the bandwidth frequency. Its unit is radians/second. To convert to hertz, $$ f_{\text{(-3 dB)}}=\frac{\omega_{\text{(-3 dB)}}}{2\pi} $$
