What's the mechanism behind disposable syringes jamming? How do you prevent this from happening or reverse the effect? They are a lot cheaper.
The problem is that once the syringe is pressed all the way in, the plunger sticks and can not be pulled back out.
  • 3
    $\begingroup$ Probably a safety consideration to prevent reusing needles. Render the syringe useless after one use and it can't be shared with another person. With the spread of HIV and other diseases from intravenous drug use (legal or otherwise), one can see why it's a feature instead of a design flaw. $\endgroup$
    – grfrazee
    Commented Oct 19, 2015 at 15:22
  • $\begingroup$ Also, I know I've bought syringes at Farm & Fleet (a farm/light industrial supply store) that didn't jam. I think they were for veterinary use, though. Worked for the school project I was doing (simulating a hydraulic pump). $\endgroup$
    – grfrazee
    Commented Oct 19, 2015 at 15:25
  • 5
    $\begingroup$ If you could post pictures of jammed and un-jammed syringes, this may be a good question. It addresses product design and product safety, and I'm sure there was some good engineering that went into making the syringe jam reliably without sacrificing usability. $\endgroup$
    – Carlton
    Commented Oct 19, 2015 at 16:22
    $\begingroup$ I would like to admonish OP for seeking to circumvent the auto-jamming mechanism - it's designed for safety! If they're cheaper, all the more reason to not need to re-use them! $\endgroup$
    – Chuck
    Commented Oct 19, 2015 at 19:46
There's a story on them at PBS. From the article:
A nurse injects a patient with a syringe of antibiotics, reloads and moves on to the next patient in line. The syringe isn’t sterilized, the needle is not replaced, and the patient is at risk of contracting a disease from the very shot that is supposed to cure him.
About 40 percent of all injections are given with unsterilized, reused syringes and needles, reports the World Health Organization. An estimated 1.3 million deaths — and 21.7 million new Hepatitis B infections — occur each year as a result of the unsafe practice.
The devices, called auto-disable syringes, jam up after one injection and can’t be reused. The casing is engineered to break if someone tries to forcefully refill it.
Regular disposable syringes can also make their way back into the marketplace after being used. People will take syringes from a health clinic’s trash, wash them and repackage them for resale.
“You can find in a market a perfectly well packed syringe, then you look closely and you can still see some blood in the syringe from the last person,” he said.
The article continues with all the reasons you can think of for not wanting to re-use a syringe.
The syringe appears to be invented by a company called "Star Syringe", who has licensed their intellectual property to 13 manufacturers. From their website:
A small ring etched on the inside of the barrel allows the specifically adapted plunger to move in one direction and not the other. After one complete injection is given the plunger will automatically lock in place and break if forced, thus rendering the syringe useless.
The following graphic is from ZDNet
Auto-disable syringe
Finally, there's a video on YouTube that shows the operation of the syringe
