I just learnt about the difference between a fan and a blower, namely the former providing high flow rate at very low outlet pressure (<1.1*inlet) and the latter providing a slightly increased pressure with less flow rate. I was a bit surprised that it was just this considered the very different design of the two.
So I was interested in understanding some more: could someone explain me why there is such a difference in the aerodynamic design (fans having very few blades but quite big, axial flow, blowers a lot of small blades, centrifugal/mixed flow, diffuser...)?
Also, at university the course of thermal machines taught me that turbocompressors have a characteristic curve like this: do fans and blower have an analogous one?
    $\begingroup$ Fans and blowers do not have hard definitions, there are several designs of each to consider and overlap in the middle. $\endgroup$
    – Tiger Guy
    Commented Dec 9, 2023 at 8:22
  • $\begingroup$ Fan blower compressor... There's an optimization problem in there somewhere that applies to wind turbines and fans that provides the most effect from 3 blades due to structure (to bear axial loads) and area that each blade applies to with large axial flow. With outward radial flow, you get the natural effect of a diffuser (opposite of a nozzle) building up pressure via reduction of velocity and increased area. I somehow feel like I answered something like this before... $\endgroup$
    – Abel
    Commented Dec 13, 2023 at 3:39
